First of all I would like to greet everybody sharing this hobby 🙂
I have so far completed 2 speaker projects:
- an introductory 2-way based on cheap Polish drivers, which turned out very nice and I am still using it on my desk with the computer
- ported 2-way based on Vifa drivers with pretty standard x-over. This also has given pretty good results.
Right now I am completing a more serious measurment tools (Based on Audua SW), and I am planning a new design.
I would appreciate any comments and suggestions.
It is going to be a sealed 2-way + powered sub (acting as a base for the 2-way?).
It is going to be powered by a tube pre-amplifier and a solid state power-amp, possibly replaced with bi-amping later. The ultimate goal would be something like tube pre-amp+pass aleph+subwoofer amp.
I have brought 2 NHT1259 drivers from the US, so these are going to be the (sub)bass drivers. Also the project of the enclosure for the NHT 1259 is pretty standard - sealed enclosure of about 90 ltrs. It is going to be crossed in the region of 100-200 Hz, depending on the mid-bass unit.
For the mid-bass I have initially chosen the Focal 4v3211, which I have spotted for Euro 25 each. I was thinking of 2 of those per channel. My decision is not final, I would appreciate any suggestions - let's say ut to $200 per pair. I have seen more exotic and more expensive drivers like Jordan JX92S, or Bandor 50AFSW/8, but they are hardly available for me and they don't really fit in my budget. The Focals seem and good value...
I am still thinking about the tweeter. So far I have considered:
- 19mm dome tweeters: Hiquphon OW2, ScanSpeak D2010/8511,
- more expensive - ribbons - Raven R1, or similar.
I like the idea of not having to attenuate the tweeter.
Honestly, $250 per pair of tweeters is the limit (a used ribbon might fit). Plese advice on the tweeter choice.
Regarding construction - I am considering stone as the material of the subbass unit, being the stand for the mid-high.
For the mid-high unit I was thinking of a heavily damped MDF.
I want to keep the front wall as narrow as possible and to keep the mid-high drivers as close as possible.
After completing the enclosures I want to do the measurments and design the crossover.
My priorities are:
- imaging,
- dynamics,
- enough sensitivity to drive from class A poweramp, or tube poweramp.
I would appreciate any comments or advice and I will report on the progress of the design,
Michal
My priorities are:
- imaging,
- dynamics,
Michal
Focal 4v3211 data
Some more info:
Below it the data of the Focal 4v3211 driver.
For me it looks good - I would apreciate any comments or oppinions on this driver and its suitability for my project.
Picture of the driver is here.
Frequency Response:
Impedance:
Drawing of the driver is here.
Driver data:
Fs 77.4 Hz
Vas 4.6 I
Qts 0.48 -
Qes 0.54 -
Qms 4.77 -
Re 6.2 Ohm
Sd 54.1 cm²
Cas 326E-10 m5/N
Mas 13 235.8 Kg/m4
Ras 129.8 Ohm.ac
Cms 111E-5 m/N
Mms 3.8 g
Rms 387 g/s
Ces 179.9 µF
Les 23.5 mH
Res 54.5 Ohm
BI 4.6 N/A
SPL 87.8 dB/W/m
Xmax 1.25 mm
Spec sheet is here.
Some more info:
Frequency Response:
Impedance:
Driver data:
Fs 77.4 Hz
Vas 4.6 I
Qts 0.48 -
Qes 0.54 -
Qms 4.77 -
Re 6.2 Ohm
Sd 54.1 cm²
Cas 326E-10 m5/N
Mas 13 235.8 Kg/m4
Ras 129.8 Ohm.ac
Cms 111E-5 m/N
Mms 3.8 g
Rms 387 g/s
Ces 179.9 µF
Les 23.5 mH
Res 54.5 Ohm
BI 4.6 N/A
SPL 87.8 dB/W/m
Xmax 1.25 mm
Spec sheet is here.
$250/pr tweeters fora $50 per pair mid. relax guy you can make do with less.
i would suggest to look ath focal 120ti (grey) tweeter. it needs a L pad as ost tweeter will to mate to the mid you have chosen.
also the vifa XT ring radiator or the SS 2904/70000 if budget permits
Well,
$250 is a maximum imaginable limit for a great value buy or if someone convinces me to do so... Fr example if I would decide to go for a ribbon... Otherwise I would spend a lot less.
The new ScanSpeaks are way beyond that anyway... ;-)
The mids I have found seem to be a great buy, I was looking for alternatives, the next stop would be PHLs or the new ScanSpeak , but this would exceed my budget.
Am I wrong about it? Is there anything wrong with them? Should I buy them?
The tweeters that you are proposing are all 25mm. Why?
With this mid it is possible to use 19mm tweeter which theoretically would have a better dispersion and detail.
On the other hand with a bigger tweeter it might be possible to think of a 1st order x-over. Is this the reason?
i dont find that many good 19mm tweeters out there. also i fid 25mm tweeters have better power handling.
what does teh focal 120ti cost u.
The only Focal 120 something tweeter I can get is the 120 TD5 for $140 ;-( I can though try to ask some of my friends to get them from the US fo around $80.
What about the 19mm Hiquphon and ScanSpeak units (prices around $80 as well) - what are their disadvantages?
And I am still curious if any of you did have and experiences with the Focal 4v3211?
