Problems with impedance measurement
I'd rather be quick and dirty if it gets the information I need in a trustworthy manner.
Sorry for the slow response, but... is this supposed to be a joke?
Do you check the code line by line?
Actually, yes. First I write the code, then I check my work.
It is possible to verify that the software seems to be working like it should and doing so is good practice. But that just adds one more layer of elaboration.
Uhm, is this another dimension of your joke above? Don't you test things to make sure the software (and everything else) is set up correctly and works as it should?
Some looooong time later I`ll dig this one up. Here is a measurement done on a standard wirewound resistor using a proper audio interface (USB powered Komplete Audio 6). You can see the differences to the Behringer.
There is an internal crosstalk in the behringer uca202/222, to work around this i use two, one for the output and one for the input - works great!
But even better with um22 as output since it can do higher levels of output
