I would like to post an ascii image (op amp circuit). I attempt to use *code* stuff */code* ("*" = "[" and "]") to preserve the spacing and an extra line feed gets inserted after each line of text, thusly:
Any suggestions?
Code:
.------o--|___|---.
C| --|-\ |
C| | >----o-->
C| .--|+/
GND GND
Any suggestions?
elseif said:I would like to post an ascii image (op amp circuit). I attempt to use *code* stuff */code* ("*" = "[" and "]") to preserve the spacing and an extra line feed gets inserted after each line of text, thusly:
Code:.------o--|___|---. | | | | | |\| | C| --|-\ | C| | >----o--> C| .--|+/ | | |/| === === GND GND
Any suggestions?
This is a fault of the software for this forum. ( http://www.vBulletin.com )
More precisely the php script used to handle your post.
The tag [ code] means that everything inside should be preserved just as entered, character for character.
Now Windows add 2 different chars for ONE linebreak:
\r\n
while Unix based systems adds only
\n
where \r = return and \n = newline
Both these corresponds to one HTML <br>
Now, somehow the script that handles posted stuff within the [ code ] tag
adds not only one <br>, but two <br><br> for each newline.
This could be easily fixed in a php script, that deals with Windows vs. Unix different ways
to announce one new line in post forms.
Probably, hopefully, vBulletin has fixed this, in later versions.
I would have a guess www.diyaudio.com uses some really old version.
Which by data age measurements is >= 5 years back dated version .. or even more.
Regards Lineup
