I have built Zen line stage some days ago. The preamp is working and the all voltages are fine. The problem is that I want it used as unbalanced preamp( I got unbalanced power amp and CD player) so I put at the input of preamp -OUT to ground and +IN to signal. At the output I put +OUT to power amp and
-IN to ground.
It is right to do like this?
The main problem is that I get too much gain at the output. For R15 I used 430 ohm and at the input, I put 10k log, but I get too much gain for my Leach power amp.
Thank you for any ideas!!!!!
-IN to ground.
