Problem with signal sensor
I would refine or modify the circuit so that it triggers the heating immediately, and delays the onset of B+ by a couple of seconds. After the input signal ceases, it could break the B+ with a couple of seconds time constant, and break the heating after 1 minute or so.
An op amp without feedback won't do you any good when amplifying a signal linearly. For my purpose I just want any signal above 5-10mV, to slam the output from rail to rail, so the highest possible gain is desirable. Every datasheet has an open loop gain/temperature graph, and you can always read off of it, how affected will your circuit be. Maybe I can have an op amp amplify the signal linearly 10-15 times, and then run it through an OpAmp based Schmitt Trigger, with two threshold levels. This might somewhat improve the stability.
