problem with ported box volume (Pionner subw)
Hi, i have a subwoofer Pionner TSW 1040C and i want to make a ported box for it.
Using different software (WinISD) i obtain a volume for a flat response of about 30 liter while Pionner suggest to use a smaller box of only 18 liter (see attached).
Maybe if i use a larger box i damage the speaker?
Pionner 1040C spec:https://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_3424/49032TS-W1040C_200012301332368370.pdf
differente response diagram (green pionner box, red my larger box)
If you make it even bigger, you get a nice low end roll off (curve more like sealed), nice because it is compensated by room/car gain, and you end up with a flatter curve.
If you design it flat, big change it will sound boomy as the lower frequencies gain more from the room. For outdoors, flat is fine.
