i have an Onkyo A9511 amplifier, which still works fine. However, when it is still cold, the sound is cracking or even absent. fiddling with the source selector makes it disapear. When the amplifier runs for half an hour or so, it works perfectly. Could anyone give me a suggestion what the source is of this problem and how i can get started to fix it?
cheers, Marco
cheers, Marco
unclejed613 said:sounds like dirty or oxidized contacts on your source switch. try cleaning the switch contacts with something like De-Oxit. also check any connections between the circuit board and the switch for bad solder. i usually just reflow all of the solder just to make sure......
The things to often need a replace or fix
in old amplifiers:
- Switches on/off in the front
- Source selectors, that you turn
- Potentiometers, especially volume, which is used often
- Wet Electrolyt Capacitors, often in power supply but also sometimes in circuit
First to get worn out is anything moving, mechanical stress
and anything having liquid, will dry out.
lineup
