Problem with gainclone
I have built a inverted GC based on Peter Daniels simplified
schematic. It works great. However, one day I had a soldering
gun plugged into one of the wall outlet where the GC is plugged
into also, and I was working on soldering my speaker crossover,
the GC was powered on, and I could here a loud pop whever
I release the trigger of the solering gun. Squeezing the trigger
heat up the gun, but that does not cause any pop, only
when I release the trigger which stops current going to the
gun that I hear the loud pop through the speakers that
are driven by the GC. Anybody has seen this problem?
Anybody knows how to fix it? I have done the same test
with other commercial amp, and they dont have this problem.
One thing I need to add is that I used a IEC power socket
in the GC and I dont have a commercial power conditioner to
plug my GC into to see if it helps or not.😕
I was not soldering the amp. The amp was closed/boxed up.
I was soldering on some speaker crossover circuit.
I have a feeling that soldering gun does not matter in this
case, I could have used a hair dryer and would have noticed the same problem.
