Problem simulating SE 300B tube amplifier
Hello, would like to build this 300B SE tube amplifier. The circuit is said to work fine, taken from a serious book, but first I would like to run a simulation on LTspice. Uploaded the LTspice project along with the tube models, output transformer model .SUBCKT and .asy symbol.
The simulation runs with apparently no errors, but I can see that the first stage has not enough gain and finally there is a very small signal over the output transformer output primary and secondary.
Some notes about the proposed simulation:
1. I am not a simulation expert, and I manage to run analog simulations regularly, but I am a newbie to tube simulations. Yes I have experience in electronics and built a couple of simple tube amplifiers.
2. the tube models used are taken from Mr. Ayumi Nakabayashi's model collection, and I have used them without problems, except for these 3 tubes that are here for the first time. I have edited Mr. Ayumi Nakabayashi's models to work fine with LTspice, in which the '^' operator has been replaced by "**" in al expressions. This was originally designed for TINA simulator, but after this syntax correction it works fine now for LTspice.
3. I managed to implement an output transformer using the model I found here: Dmitry Nizhegorodov . Correction of the original different parameters has been done to match the values of the Lundahl model LL1623 transformer.
4. I included a 100 MOhm R20. Without it LTspice complains about an open node. I also did with R19 that references the output transformer secondary to ground.
5. R10 and R11 are replacing an adjustment potentiometer.
6. I have included the Xfmr.asy that should be copied to correspondent the LTspice program model directory. In my case it is located at c:\Users\Bob\Documents\LTspiceXVII\lib\sym\Misc\
Could you please help me to make this simulation run, and sorry for any errors that you may find.
Kind regards
  • 300B_amp_simulation.zip
Done nigelwright7557, and it worked ! 21 W output. 11 W output RMS with 100K feedback resistor. Thank you. I think this should be a much "standard" value for a FB resistor. Could be a typo.
MarekH, yes, I use this K coupling factor if I pick individual inductors from the menu, but in this case the transformer follows a model. You can see the model in the link I included in my first post.
The coupling is stated as:
KALL LP1 LP2 {1-1/(QFCTR)} ; COUPLING
The current feedback resistors give a gain of 1.8 which is nothing. I would try making gain at least 10 and see how you get on.
If you follow your signal through it looks to me like you are using positive feedback. I think its confusing the simulation.
The feedback circuit is right just wrong component values. The feedback signal is in phase with input so it raises the cathode when positive feedback. I simulated it just convince myself. The gain of amp is feedback resistor divided by the 150R. With 1k5 feedback resistor you get a gain of 10. Adjust to suit your needs.
Thank you Nigel, I will experiment with several values. And if it is working with positive FB it could be confusing the simulator, I agree. Is positive FB OK here?
I think that fortunately the output transformer model seems to be working right, which is good news for me because it was hard to figure out a reasonable model myself for this component.
