Problem simulating poweramp in LTSPICE
You havn't filled in 'Ncycles' in your two AC voltage sources - put in a reasonable number there like 5000. Then you'll see the amp comes to life but I suspect you're not able to get enough bias for those MOSFETs because either your current source is too low or the bias spreader resistance is too small.
You'd get it going quicker if you dispensed with the AC voltage sources and used DC voltage sources for your rails until you've got the bias conditions set up correctly. Then you can use AC analysis which will calculate your operating point more quickly than waiting to see what happens with transient analysis.
Yes it works but I still don't get why in the real amp I'm using a 500ohm trimpot and still get 120mA in both mosfets.
Also, using P2a = 530ohm and V+,V- = 42V I get 120mA in mosfet M2 but only 90mA in M1.
Can it be a problem with models?
I'm getting 5.4mA in your CCS (Q4,Q5) which indicates you'd need 1k4 for your bias spreader to get 7.5V between your gates. So your 500R trimpot is in series with what resistor value?
Incidentally your 120mA/90mA bias split is most likely caused by a DC offset at the output.
Snipping the short across P2b I'm now getting 60/80mA which is fairly close agreement with your real world amp. Remember vertical MOSFETs have a strong negative gate threshold voltage coefficient, meaning the bias increases as they warm up. The model doesn't simulate that.
