Probably easy clock question
Hi!🙂
I have bought a seconhand Philips player, and I`m going to go non oversampling.
So my question is:
When I remove the saa7220 digital filter I have to feed the clock (Tent clock) directly to the clock input at the saa7310 decoder. Do I then have to add a resitstor (200K- 1M) between the the clock input and the clock output on the 7310? Or is this resistor only needed when it is fed by a passive crystal?
Thanks🙂
Tor Martin
Please leave the resistor where it is or you'll experience weird behaviour of your cdplayer !!! Remove only the crystal and the 2 small capacitors.
edit: I misunderstood your question probably. When there isn't a resistor in the datasheet/typical application of SAA7310 you don't need one. It's too late now to check.
Hi!🙂
Thanks for answering, Jean Paul!
Sorry, my question may have been a bit "unclear".
The player is a cd 820, and it uses the same mainboard as cd 620, marantz cd40.......
The 7310 gets it`s clock signal from the "xsys" pin on the 7220 without having a resistor between it`s "X-in" pin and it`s "X-out" pin.
The 7220 have the standard 220k resistor in paralell with the crystal, between x-in and x-out.
So I thought this was easy, after I remove the 7220, I just feed the x-in pin of the 7310 with a tent clock, the same way is was fed before. But then I found this page where they add the resistor: http://xoomer.virgilio.it/hi_fi/jitt.htm
Hopefully this is not needed, because it would go between pin 25 and 26 on the smd version of the 7310, and I would rather avoid soldering anything between thoose small pins.
Tor M
Tor M said:
Hi!🙂
Tor M
Hi Tor,
This way you do not need the resitor. The resistor is often present to make sure the crystal oscillator is correctly biased
succes
Spindle motor spinning very fast and/or skipping ( behaviour like disconnected clock ). The internal ports locked like a comparator without the resistor. Modern chipsets have the resistor often built in as you can see in their datasheets. I know its supposed to be used with crystals.
After having experienced this phenomenon I leave the 220 K to 1 M resistor where it is as it does not do harm.
Please note that I am talking about older generations of Philips chipsets here.
Tent clock - SAA7310
I am installing a Tent Clock (XO2) in a Philips CD624. The original arrangement has the crystal connected to the SAA7321 Bitstream DAC (with built in filter).
The standard installation involves removal of the crystal and accompanying 2 capacitors and then connecting the new colck module to the points vacated by the crystal.
Is this the best implementation?
Should I also make a connection from the clock module directly to the SAA7310 decoder?
If so - should I cut the clock trace between the SAA7310 and SAA7321?
carlosfm said:
Tor, I don't know that player, but check it out if removing the 7220 you don't loose the S/PDIF output.
If you won't ever need it, fine.😎
Hi Carlos🙂
Yup, I`ll loose the S/PDIF when removing the 7220, but at the moment I don`t need it.
I have plenty of TDA1543s, so for a start I thought I`ll use one of theese in a i2s direct connection with an passive I/V and fed from battery.. Something like Peter Daniel did in his Marantz. Maybe later I start experimenting with different outputstages for the TDA1541 that is in.
I bought 2 players, this philips, and a Marantz cd 40. They both use the same mainboard. The plan was to modify the philips and keep the marantz as it is so I can compare them as I go along.
Tor M🙂 🙂
