Fiberglass is a pain to work with but it is strong. If you brace well, you can get the needed strength otherwise, without the mess.
But then maybe you want to use fiberglass; and if so, many paints will stick. That will be no problem.
The real advantage with fiberglass is the many shapes you can form. You could make any shape out of paper mache and then cover it with fiberglass and have a sub. Let your imagination run wild. Mickey Mouse, pumpkin, girl friend, what ever.
