Precision Resistor GB? General Resistance (Rhopoint) GG102
I use the 8G16 0.1% version and I can't see any real benefit of paying the much higher prices for the GG102s &/or 0.025%, etc Do the GG102 versions sound any better for audio purposes?
Mind you, I don't have any circuit requirement for better than 0.1% accuracy and the noise and stability appears to be the same for the different versions .... am I missing something obvious?
Also, what is the difference in sound between the Manganin resistors and the Zerenin resistors? It's pretty easy to hear the difference between the Manganin and the Isotan/Constantan
I would love to know the answer to jameshillj's question so I added a pair of 1.5k 0.1% version of each of the 3 resistor lines to my order. These can be a test set to be sent around for folks to compare, and then we can know (at least as much as ears will tell us).
We have much more than the minimum order and can probably split it into 2. If you want to wait until the "what's the difference" question has more answers, please let me know.
Perhaps the more compact size might reduce the 'noise' or something - I can't see any specs about that - otherwise the conductor properties seem to be the same.
It's interesting Paddy that Element14 here in Oz (Farnell Australia) is listing some 8G16D resistors (about 20 values) for just under A$10 - listed under the Rhopoint name - a few 5G10D too but those are A$12.50. These are the 'basic' 0.1% version.
I'm amazed that you could get such a low volume, special tolerance purchase today from any manufacturer - just saying ...
I occasionally see mention about another similar material called Zerenin, or Zeranin - it's similar 85% copper, about 7% Mn and the last bit is Sn - apparently it has a different temperature behavior but from the little I've seen written, it also has a different 'sound' characteristic (probably quite small), but it'd interesting to see a sample of resistance wire to try it out.
I too was surprised at the low minimum from the manufacturer, but then again resistors aren't their main business: Prime Technology . It could be that the precision resistors are needed for their other lines and retail is a bonus?
They also do short-run assembly, and given their other markets I imagine they're pretty good at that!
Separate post to keep things clean: Coming down to the closing point for GB, listed below.
Please check and verify that I've gotten your order correctly!
I'll send everyone a PM this evening with a total including likely postage to your location. Please pay up by Wednesday 31 March and I'll send in the order.
Changes/additions/deletions are all fine up until 31 March, then it's set in stone.
Paddy Garcia 2 100R 0.1% GG102 18.41 36.82
Paddy Garcia 2 1k5 0.1% 5G10 miniohm 11 22
Paddy Garcia 2 1k5 0.1% 8G10 econistor 7.16 14.32
Paddy Garcia 2 1.5k 0.1% GG102 11.13 22.26
Vunce 2 1.5k 0.1% GG102 11.13 22.26
Vunce 2 60R 0.1% GG102 18.41 36.82
Luchoch 2 2100R 0.1% GG102 18.41 36.82
kuka 4 100R 0.1% GG102 18.41 73.64
wealas 4 1.5k 0.01% (add 50%) GG102 17.145 68.58
geoturbo 4 120R 0.01 (add 50%) GG102 27.615 110.46
badrisuper 2 1.5k 0.1% GG102 11.13 22.26
SigFire 4 1k0 0.1% 8G16 7.16 28.64
SigFire 2 2 x 100R 0.1% 8G16 9.97 19.94
SigFire 2 1k5 0.1% 8G16 7.16 14.32
SigFire 1 10k 0.1% 8G16 7.16 7.16
The manufacturer doesn't list 150R as a standard in any of the three lines, so not in the table above. That doesn't mean Rhopoint wouldn't stock them, just that we can't get them off the shelf in this GB, sorry.
Probably worth ordering through Rhopoint even if we did order custom: GG102 Squaristor in ranges 10R-249.9R would cost $26.91 each in quantity < 10. Happy to sign you up for the standard pieces in the GB if you like, just PM.
Very good - that's:
tatosdk 2 200R 0.1% 8G10 econistor 8.67 17.34
tatosdk 2 2000R 0.1% 8G10 econistor 7.16 14.32
tatosdk 6 2500R 0.1% 8G10 econistor 7.16 42.96
tatosdk 2 3000 0.1% 8G10 econistor 7.16 14.32
tatosdk 2 100 000R 0.1% 8G10 econistor 9.40 18.8
PMs sent with order details and totals.
Unless otherwise specified, resistors will be sent to you via first-class mail, as a letter, which means no tracking or insurance, but also no customs declaration. If desired I can ship as a package, for about $15-17, which provides tracking and insurance and also customs. Your choice risk, so your choice.
