Precision Power P900.4 Resistor Values Needed
I need the resistor and capacitor values for the output filter.
They burned so bad that the relays are also melted and not working!
Thanks Perry,
The capacitors are 160V 1uF and with 250V 470nF in series (I was able to remove enough burnt glue from one to identify the capacitor). I will use 10ohm resistors, that is consistent with all the examples I have seen. Thanks again!
