From Linkwitz FAQ
Q34 - What is the optimum Qts for the drivers of a dipole woofer?
A34 - The low frequency roll-off of a woofer and its associated group delay are optimal, from what I have observed, when they follow the response of a 2nd order highpass filter with Q = 0.5. When a driver is mounted in a dipole W-frame or H-frame its mechanical resonance frequency Fs decreases to Fd, due to air mass loading, and Qts increases by a similar percentage to Qtd.
For example, a driver with very strong motor, Fs = 18 Hz and Qts = 0.2 might have Fd = 16 Hz and Qtd = 0.22 as determined from an impedance measurement of the baffle mounted driver. With Qtd < 0.5 the low frequency behavior of the woofer is characterized in the complex s-plane by real axis poles at -69 Hz and -3.7 Hz and by 3 zeros at the origin. One of these zeros is due to the front-to-back dipole cancellation with its 6 dB/oct low frequency roll-off. The frequency response of this 3rd order acoustic highpass filter must be equalized to obtain a flat response. A suitable target response could be Fd = 20 Hz and Qtb = 0.5. It is easily realized with two shelving lowpass filters. The first filter with a pole at 20 Hz and a zero at 69 Hz corrects for the low Qts of the driver. The second filter with a pole at 20 Hz and a zero at 400 Hz compensates the 6 dB/oct roll-off due to dipole cancellation. The 3.7 Hz pole is low enough in frequency so that the response is dominated by the 2nd order roll-off below 20 Hz. An advantage of a low Qts driver is the ease with which it can be equalized for an optimum response with Q = 0.5.
A driver with a smaller motor might give Qtd = 0.7 and Fd = 20 Hz, which leads to a pair of complex poles in the s-plane. This can be readily changed to a 3rd order Bessel highpass response by using a shelving lowpass filter with a pole at 20 Hz for the necessary dipole roll-off compensation.
Likewise, if Qtd = 1 and Fd = 20 Hz, then an additional pole at 20 Hz, from the dipole equalization, leads to a 3rd order Butterworth acoustic highpass response. Third order filters introduce more group delay than 2nd order ones. It is therefore advantageous to use Qts < 0.5 drivers, even when they require driver roll-off equalization in addition to the normal 6 dB/oct dipole correction.
