Hello to all, recently I was thinking about some devices that can be a nice idea to be builded.. according to my researches, not found any devices with this capabilities on the marketing... If such devices exists, let me know..
Preamp with phono stage + analog active crossover built in (2 or 3 way)
Preamp with phono stage + DSP + Room Correction built in.
Multi Channel integrated amp with phono stage + analog active crossover built in (2 or 3 way)
Just one of many hundreds on the market;
Behringer CX2310 V2 Pro Super-X Crossover at Gear4music
And a really super one;
Behringer Ultradrive DCX2496LE Loudspeaker Management System at Gear4music
I'm talking about a conventional preamplifier, with a phono stage built in, and also with a active crossover integrated on his output.
about the multi channel integrated amp with phono stage and active crossover (in that case a DSP) I only know, Trinnov, there's others?
One of the main issues with active crossovers done in analog circuitry is that the crossover frequencies are hard to make variable without 4 or 6 gang pots with good tracking, so the circuit is bound to a fixed set of crossover frequencies, ie specific to a particular loudspeaker.
This suggests the active crossover comes with the speaker, not the preamp.
Right now I use a minidsp as a preamp. It has one analog and 3 digital inputs and all the outputs I need. There are models in the range with Dirac room correction as well. But they are not super cheap when you add those features.
One thing that would be nice is a standard enclosure for preamp + ancilliary circuitry - share the connectors, power supply, plugin modules for whatever you want. Its been done but only proprietry I think...
It's DIY only really, but a miniDSP miniSHARC could sit nicely at the centre to do the heavy lifting.
Hello to all, recently I was thinking about some devices that can be a nice idea to be builded.. according to my researches, not found any devices with this capabilities on the marketing... If such devices exists, let me know.....
I have one of these; it's a good unit:
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project
Analog-Precision
- Analog Line Level
- Preamp with built in active analog crossover and other ideas...
