preamp/mixer combo
Hello DIYers
First of all I know these things have been on here quite a few times and I have read most of the threads about it but I still have few questions.
Ok so here it goes
First of all I am trying to do something like this:
Will there be a big problem if I put all this in same case?
Ok so there will be ODAC or something similar + two external stereo inputs one RCA and one 1/4" jack.
Everything will be fed into inverting input on opamp (don't know whitch one yet) and after the first one it will go to second one to correct phase. Is second one even needed?
After this stage I don't know exactly how to continue. How to connect both speaker and headphone amp? can both be driven from opamp output or should there be something in between?
I want to use one potentiometer for volume for both amps where should I put it on input or output of opamp?
Here is schematic I have so far. Only one channel shown
Ok after some simulation that is probably wrong I got some results
Schematic in spice (resistor numbering not the same)
and result is
I'll try without R5 across pot.
Is this changing volume with gain same thing as attenuating at input? What is better?
Now about PS for this would it be better to have regulators on same board or on separate?
Hello,
The circuit looks already good. Use 10u for C1,C2,C3 (better availability and similar price). C5 is to low. Your need at least 10u if the input impedance of the next step is taken into account.
It is also possible to use an attenuator at the input. Small advantage of your current circuit is, that no current flows through the middle pin of the potentiometer.
It is not essential that the power supply regulator (LM317 or similar) is on the same board. If it is on the same board, the output impedance of the regulator is somewhat smaller (no cable).
It is important to have decoupling capacitors near the opv.
Good luck,
Udo
Ok bit of an update where I am so far. Layout is probably pretty bad.
Potentiometer will be mounted on front plate of the case so I just left sockets for it there.
I also tried to implement some sort of relays for turning outputs on and off.
Any comments.
Hey
I kinda put this project aside for a while now. But no I hope I'll actually continue.
First of all thanks udok for those links I helped to read a bit more about regulators.
Ok so this past month I was still thinking about this circuit and decided on few changes to it.
First of all two inputs will be good enough One for DAC that will sit inside same enclosure and one for external gear. After talking with one of my co-workers he nudged me in SMD direction :). So with this change I have enough space on same PCB for preamp and headphone section. Now I can make powersupply from two secondaries not with voltage doubler like I had before.
Found this link and maybe I should implement something similar in my design. Like add buffers on input and buffer inside gain control.
I'll draw new schematic today or tomorrow.
