In my latest pre 6DJ8 SRPP I have excesive HISS noise. It's clean hiss, not buzz, not hum.
Every few seconds the hiss is going louder.
On the scope the only thing I can see is some hi frequency stuff riding on top of <1mV of 100Hz noise. Scope is upto 15MHz.
Heater PSU is AC with one node thru 100nF to AC earth. Heaters are not on DC potential.
HV PSU is 220uF-25H-100uF-1K-100uF.
Circuit runs on 205V ~7mA/channel
Any ideas welcome.
PS: replacing the 6DJ8 with 6N1P reduces the hiss by 50%.
Any ideas welcome.
SY probably nailed it, but I once had a noise I couldn't figure out and then when I connected the heater to a positive voltage it went dead silent. So it turned out to be leakage from the heater. The old RCA books recommend offsetting the heater to positive 20-40Vdc, whether using AC or DC heater current.
It could also be a dead tube, I've got at least a few 6GH8's that make a mess when swapped into Frankenhouse. But that you tried at least one other tube, that's unlikely, especially if new tubes (the 6GH8 I speak of probably saw decades of a television, ugly service for anything
Tim
Tim
SY said:SF, excellent point, and especially so if the top tube in the SRPP doesn't have its heater properly biased- running near or over the max heater-to-cathode voltage rating is poor practice.
Yes.
I solve the problem by using a seperate bottle for the "topside" and floating the heaters, bypassed to ground with a low value (~2.2uF) 350V 'lytic. That way if you do get a heater-cathode short, not a lot will happen (and your cap won't go through the roof!). Bottom bottle can be DC grounded, attached to the rest of the system string.
It's a method I've used for years and has proved quite foolproof
Can you please explain?Geek said:
Yes.
I solve the problem by using a seperate bottle for the "topside" ...
Tried the following.
Metalic clip-on shield top of the tube, no imporvement.
Elevated heaters on ~50V, big improvement.
Local bypassing, no improvement.
Hiss is still there listenable on my 100db horns.
Will try ferite rings on grids, replace the volume pot.
Can it be a bad socket? I use some teflon, silver plated, British made salvaged from military scrap.
'k, no problem
The noise is induced from the H-K, probably caused by near-breakdown levels of voltage on the top tube.
6DJ8 has two elements. Two tubes are requred for SRPP stereo operation (4 elements total). Rather than using one tube to handle each channel, use one as the L+R bottom of the totem pole and one as the L+R top. The "bottom" tube's heaters can be tied into the existing heater string. Add a small transformer whose sole purpose is to feed the heaters of the "top" tube. Leave the leads isolated from DC, but not AC with the capacitor.
Here is an example from my Akai tuner I "tubeified":
http://geek.scorpiorising.ca/contrib/Geek/6N1P_srpp.png
The 6N1P on the bottom has a DC grounded heater, the 6DJ8 ontop, has an isolated one.
- Tubes / Valves
- Preamp hiss noise
