Now I am finished with my F2J it seems like I need a good preamp to go with it.
I don't need real amplification but possibly a buffer and attenuator. A B1 board is in the process of making.
Since this amps input impedence is only 10K( compared to F2 , 50K)
Is B1 the right design I should look for ?
Zen is right. I would use 200R, Problem solved.
I believe the DCB1 (Salas' version) used 200R series resistor. Should be fine especially if interconnects are short and not fancy I would think.
But B1 Rev2 is probably the way to go, assuming one has the jfets.
