PRE-Sale - TU-8600
The regular price will apply after August 15, 2017 .
Please note that TU-8600 is a limited version and there are a limited numbers allotted outside of Japan.
There are only 50 pieces of TU-8600 available in September that can install Lundahl LL2770 and a limited number of regular version.
The new 300B amp has a lot more improvements from its predecessor (TU-8300R).
The noise level of TU-8600 is as low as 1/10 of the TU-8300R. Amazing design..
The most anticipated amp of 2017 - Wall of Sound
The New Elekit 300B SET Arrives At WoS | Wall of Sound | Audio and Music Reviews
Quick Update on our Most Anticipated New Amp of 2017 Review | Wall of Sound | Audio and Music Reviews
If you are interested, I will accept preorder.
Your pre-order will be charged the day the kit is ordered.
We do this to allow cash in advance for payment to our vendors to keep the price you pay as low as possible.
DIY audio is a very focused market.
We are a small firm with huge passion, attempting to offer the broadest range of kits possible to those interested in this exclusive pursuit of ultra-high quality audio reproduction.
Thank you for your support
I offer assembly service. Assembly cost is $200.00
Stock Resistor
- 1/2 W KOA CFS1/J 5% carbon film resistor
-2W, 3W KOA CFS1/J 5% metal film resistor
Resistor upgrade option
-1/2 W TAKMAN Audio Grade Carbon Film Resistor (CUSTOM MADE for TU-8600) (REX 50G 2%)
flags_1
LL2770
<a href='https://postimg.org/image/kbzde8k6j/' target='_blank'><img src='https://s25.postimg.org/40z9hx7ov/IMG_0983.jpg' border='0' alt='IMG_0983'/>
Pre sale ENDED AUGUST 15, 2017
 300B SE Tube Amplifier Kit
 Tubes : 300Bx2, 12AX7x1, 12AU7x2 *Tubes are not included!
 Rated output : 9.2W + 9.2W (THD 10%)
 Rated input : 320mV
 Residual noise : 36µV (IHF-A)
 Frequency response : 7Hz-40kHz (3dB)
 Input impedance : 50k
 Output impedance : 4-6.30, 8-160 (Select by the switch on the rear)
 Input terminal : LINE x 1
 Output terminal : Speaker terminal
 Gold-plated screw terminal (banana plug usable)
 Power voltage : AC100/200V 50/60Hz (3P inlet)
 Power consumption : 90W
 Dimensions : W385xH217xD325mm (excl. projections)
 Weight : Approx. 12.6kg (excl. power cord)
