what do you guys use as a Pre amp for the gainclone as we know it here on DIYaudio or do you use another directsource such as cd player or dvd player with volume controle ?
Jean-Pierre
Jean-Pierre
depends on if i'm using active filtering or not. if i use active filtering then sure, not much reason not to use it. if it's just an amplifer without need of a balenced input buffer or any processing, i'd just use a non-inverting amplifer with suitable pot.
