Pre Amp for TV hookup? (Hypex/Purifi)
Would a couple of resistors work?
Left to left stereo, right to right stereo
Left also to resistor, right to another resistor, and the two resistors to the mono
Basically, put resistors in both arms on the Y
I know it’s not ideal, and some left will bleed to right and vice versa, but it might be good enough for the OP
Reactions: mamocel
2 resistors of 1 M.ohms for summing the left and right channels and an op amp to re-amplify and reduce the output impedance of the central channel.
I have already done it, to create a sub channel from a stereo signal, forgetting the low pass filtering here.
There are several diagrams lying around on the web.
After several attempts to get a decent signal controlled by the TV's remote (mute, volume), I gave up and bought a Topping E30 DAC. Inexpensive, unobtrusive, optical input, and has its own remote to mute and control volume. Sounds excellent to my ears, way better than what the TV was putting out at any rate. Obviously you can spend more money to get something more audiophilic, but you do need one with a remote.
I researched TVs and found that very few offer a line level output that is controlled by the remote, which to me seems the most obvious thing someone might want to connect to a stereo. Strange how the corporate minds work.
I don't understand why choosing a superb amplification that cost in the 1.5k - 2k ballpark to then cheap out on the DAC.
It is perfectly respectable to go cheap, but then there are AVRs that properly handle 3 channels or more for less than 500 bucks.
