Practice headphone amp
I hope this is the right sub-forum to post. I'm in doubt as this project also involves solid-state components and it's an instrument amplifier. Feel free to move it to the most appropriate space.
I would like to build a guitar practice amplifier for a friend of mine. He would rather play with his headphones in order not to bother his flatmates.
Having a spare 12AX7 tube on hand I though I could go with a tube preamp section and a solid state final stage to drive his headphones (they should be low impedance, certainly below 100ohm).
Using the schematic I have attached * I would only need to buy some passives (I already have a suitable HV power supply) and I already have the tone controls sorted out.
So I guess what I am missing is a solid state final amplification stage to drive a pair of headphones. My aim is to use a single rail 12V supply which I already have on hand, but for other voltages I am open to using a buck converter.
I am asking for your advice on two topics:
  • What driver circuitry should I use for the headphone amplifier?
  • Do you have a different/better tube preamp schematic (using the 12AX7)? is there anything you would change in the current design?
* The schematic attached comes from here, but I've uploaded a copy for future-proofing.
The 12AX7 is going to need a High Voltage B+ to work well.
You will need a 12V supply for the solid state amplifier, and a 12V to B+ Boost convertor for the 12AX7 or other tube stages.
You could say this belongs as a tubes / valve thread.
You could say this belongs as an instruments and amps thread.
Or . . . because you already seem to have most things worked out other than the solid state output amplifier . . .
You could say it belongs as an Solid State thread.
40 Years ago, I would just have used an LM386 8 pin dip solid state amplifier.
After all, this is a guitar amplifier, not a high end Hi Fi Stereo amplifier, Right?
The solid state thread fans should be able to suggest some sort of simple IC audio amplifier chip.
Just my opinions.
