PPI PC4100
This amp had blown power supply fets..
I replaced All gate resistors (47 ohm)
I replaced all Power supply fets (IRFZ44N)
I replaced Q76,Q79, Q53 Q57,Q68,Q78 which i belive are the drivers
Q82 thru Q86 get red hot as soon as i touch the remote to the amp..
I removed the BYW29's Still same issue Q82 thru Q86 (Fets) get red hot and the amp draws excessive current as soon as i tounch th remote wire to the amp..
The other side Q1 thru Q5 (fets) remain cold to the touch..
Anyone know what im missing here?
Have you checked the switches in the preamp section? Try and inject a signal at the large mylar caps on all channels to actually verify that all channels have output, then go back to the front end of the amp if all the main channels check out. Also measure the DC offset on all the channels, if your defective channel has DC offset I'm thinking its ok but your front end may not be passing a signal to it.. Just thinking off the top of my head and remembering what my 4100 looks like inside....😉
