PPI A600
Are you sure that it doesn't have any shorted output transistors or out of tolerance emitter resistors?
Does it have ± rail voltage?
Does it have ± regulated voltage at the op-amps?
How much current is it drawing?
Does the low impedance LED light up with no speakers connected?
It only draws about 1 amp of current
All resistors are within tolerance
No outputs shorted at all
I think I found the problem I'm not getting any rail voltages
I do not get positive or negative rail voltages ..
Any ideas on what to check ?
I get regulated voltages + - 15 volts just no rail voltages
The left leg of CR2 and 4 should read 0 ohms to the center leg of all of the 6488 outputs.
The right leg of the other 2 rectifiers should read 0 ohms to the center legs of all of the 6491 outputs.
If one doesn't read 0 ohms, you may have a broken leg or solder connection on the power supply filter inductor.
By chance, one of these came in for repair a few days ago.
The transformer output feeds both the rail rectifiers and the regulated supply rectifiers. If you have a good regulated supply, that should mean that the supply is operating.
Are you sure that the regulated supply is holding it's voltage, even if the amp is left on for more than a few seconds?
