PPI A600 offset
I’m not following what you’re saying.
You asked me to put the black probe on the non-bridging terminal, which I understand to be the common bussbar between the two channels. This makes sense to me, since it’s the common point of the secondary of the power supply.
Next you said check the range of the offset pots while reading pin 3 on the driver cards, and I noted a range of -6 to +15mv with the positive probe there.
So I don’t understand what you mean when you say how could it go to 15 if it’s -3, both cards do the same thing when reading pin 3. Did you mean read the output terminal instead???
I’m lost.
