PPI a2150: FET driver blown? (waveforms attached)
I have a circa 93 PPI art series 2150 (600W bridged) that sustained thermal damage due to my friend stacking this amp on top of another a2150 :whazzat:
I just can't let this thing sit on the shelf any longer so I'm going to fix it but I hit a snag today. I replaced all 10 power supply FETs with Fairchild FDP20AN06A0 parts, which should be better than what most people are using to repair their amps since they are 60V/45A/17mohm/15nC... nicest thing I could find and money is no object since I sample them 😉
Anyway, the damage consisted of a couple blown FETs and nothing else noticable so I ordered the 10 replacements and also went ahead and changed the gate drive resistors to 22 ohms like this thread suggests. I decided to make sure the sg3525a PWM driver was working right before I put the new FETs in so after I took the old ones out I hooked up the amp and watched the two gate drive channels on that chip. They looked great with 10.7 V amplitude and 2 us deadtime between pulses. I was happy so I changed the resistors and put the new FETs in and fired up the amp. About 2 seconds after I gave the remote lead 12v, the amp went from drawing 80mA to drawing 50 Amps! I looked at the gate drive and it looked UGLY. The pulses were only going to ~7 V and there was no real deadtime.
PPI drives the FETs directly from the 3525 so it seems that my problem must be the 3525, no? I guess I really need to pull the rectifiers to isolate the power supply because I was seeing some serious voltage drop across my supply wires that might've been affecting the operation of the driver.
pictures:
Here are the waveforms:
Gate drive with no FETs installed:
Gate drive with FETs installed:
Zoom-in of deadtime with no FETs installed:
Zoom-in with FETs installed... no deadtime, both outputs partially high during the transition:
Hopefully I can find a free sample for the sg3525, I would hate to actually have to spend money to fix this thing 😀
It appears that the crappy waveforms above were due to the voltage dropping very low due to high current through small wires, so to isolate the circuit I removed the transformer and here is what the gate drive signal looks like:
The amp is only pulling 97mA now so it's easier to work on than when it was pulling 50A 😉 Does that signal look like one would expect? The slew rate seems poor to me and the fact that one channel has instant 10V (10x probe) while the other has to build up to it seems very strange. In retrospect I should have pulled the secondary side of the transformer rather than the primary so that I can fully operate the power supply without a load... I'll put the primary side back on and lift the other side and see how it looks. I'm now using a uc3525 from TI and I stuck it in a socket to make things a little easier to test :angel:
It should be able to handle those FETs because lots of folks are using the irfz44n to replace them and it has a 1470 pF input capacitance whereas the ones that I'm using are 950 pF. Maybe the 22 ohm gate resistors are too low and are causing too much power dissipation in the driver? That's doubtful since it doesn't even get warm and apparently PPI changed them to 22ohm in a later rev. :scratch:
Lots of progress! :Popworm:
It turns out that one of the new FETs had already blown due to the high current in the output stage, which shorted the gate to the drain and caused those nasty waveforms. I removed this FET and it the power supply works great with the rectifier legs lifted except only 4.7 V is seen at Vc, which means the FETs are only getting 4.7V at their gates, but otherwise the square wave is very square but does have some ringing (it happens). This low Vc seems to be due to a little TO92 PNP that sits between +12V and the Vc input on the sg3525... I don't know what the purpose of this thing is but I have a feeling the bad FET killed it too since it's only rated for 500 mA. I shorted that PNP's base to collector and then I had a nice 11V square wave going to the FETs :nod:
Why didn't PPI hook Vc directly to +12V like most other designs? What does this PNP do?
The source of the massive current draw turned out to be some toasted NPNs in the output stage... after I removed them the amplifier fired up fine with +/- 40V rails but I can't put a load on it till I get that Vgs up higher to avoid blowing up the FETs. I'll be back tomorrow with waveforms and (hopefully) good news :devilr:
Replacing that little PNP driving the 3525's Vc pin didn't change anything so instead of getting covered in thermal paste while tracing it to the other little NPN's in the circuit, I just hot wired Vc to the +12V line :bigeyes: 😀 Now I have awesome looking gate waveforms and +/- 57V output rails 😎
Everything is back together (with one missing power NPN, oh well, I'm running 4 ohms stereo) but now I see the -15V regulator is dead 🙄 I reallllly don't see how PPI ever got the + and - 15 V regulators to work since they're tied directly to the output rails, which are 20 V above the max input rating (35V) of these 7915/7815 regulators! How the hell did PPI get away with this?
As soon as I get this regulator issue resolved, there will be one more art series rockin the block :hphones:
I don't have any 7915's so I decided to throw a 7812/7912 combo in there to power the op-amps. After 5 seconds of running like this the -12v capacitor exploded! I checked the voltage and it was at -49V! It seems the 7912 did NOT like the high input voltage, as I expected. The 7812 seems to have shut down instead of breaking down as it is only showing ~0.45V on the output. Again, I have to ask: How the hell did PPI make these voltage regulators live???
I removed the +/-12V regulators and hooked a +/- 15V bench supply straight to those pads and ran the amp's 12V input on another supply and it works! I even got shocked while probing the speaker outputs :bigeyes: 😀
I just can't imagine how those 15V regulators ever worked... should I order a pair of 7815/7915 and try them or should I go ahead and build my own psu on a little perfboard using higher-voltage devices or maybe a boost convertor on the 12V line with a FET to turn it on with the remote wire? This is crazy... has anybody seen special versions of the 7815/7915 that allow for higher input voltages?
How do other amps get the split supplies for the op-amps? :headbash:
Yep, sure do 😀
I got a new 7815 and the +15 V looks perfect but the new 7915 only outputs -0.68 V. I haven't messed with it this week but my plan is to lift the input pin and verify that the 7915 does work with an external supply of -25V. If it does, then I'll have to drop the voltage going into that negative regulator with a resistor, zener, or something simple like that.
Any thoughts? :bigeyes:
It's a strange power supply!
150 watts in to 4 ohms...
sqr( 150 * 4 * 2 ) + 3 = 37.64 Volts
So, the power supply should be around +/- 38 Volts. It was probably operating properly when you measured +/- 40 volts.
The power supply in PPI amps of this vintage is not PWM! It modulates gate voltage rather than pulse width. Take a look at this simplified diagram. Q1 creates a ground referenced voltage proportional to the total rail-to-rail supply voltage. This is compared to Vref from the 3523 by a differential (operational) amplifier made from Q2,Q3 and Q4. The MOSFET gate voltage is the output this error amp. When the amp idles, the gate voltage will be much lower than saturation. This would appear to defeat the efficiency of PWM, and to some extent is does. When the amp is in use the periodic demands placed on the power supply will typically cause the gate voltage to alternate between saturation and something less than saturation. PPI claimed this design reduced RFI.
The 78xx/79xx series regulators will generally tolerate Vin-Vout of 35 Volts. VCE breakdown in the series pass transistor will occur if this is exceeded. So, 15 + 35 = 50 Volts max. The bias current (not voltage!) is set by the +/- 15, so 7x15 would be preferable to 7x12.
When you bypassed Q4, the supply was no longer regulated. 57 > 50 so the regs blew. You may want to replace the filter caps as well. They are most likely 50V and 11+ years old.
I will take a look at the gate drive in my 2300 this weekend and post some scope captures. I don't recall what it looks like - haven't scoped it in 13 years. I am not sure if the waveform you saw was normal. The low gate voltage certainly was normal.
Wow, good info! :bigeyes: That explains everything... PPI just has to be different... first they buy a thermal paste factory and squeeze out 15 pounds of the stuff per amp and now I see they're using PAM rather than PWM... I wonder if their pcb revision numbers come out of a random number generator? :idea: I'll revert to the PNP and let you know what happens :nod:
oPossum is the man! I put that PNP back in and replaced the two regulators and I now have a +/- 39.6 supply and +/- 15 too! 😎 I bench tested it with no load and with 12.5V supply and ~3.2Vpp input at 1Khz I had an output of 76 Vpp on each channel just before clipping :spin:
I had some nice waveforms for you but my floppy is corrupt :dead:
