PPI 2300AM
What would cause this on Q16 ?
Is it from stress or the legs being bent and then bent back ?
Everything appears to be factory ampnhas never been repaired as far as I can tell .
The client bought the amp off someone and wanted it checked over before install .
I cleaned the wire strands from the board that I found so far
This amp was dropped off to go through it to make sure everything is fine before installing it
I talked with the guy last night and he wanted all of the caps replaced since they are 20 to 30 years old .
I told him it’s not really necessary to replace them if they still test fine .
Wondering should I replace the caps in this amp or leave them alone and explain to him that they test fine and I would be replacing caps for no reason.
