Anyone know of a source for a PP pentode PCB that I can use for a tube headphone amp. I want to build a few and give them away as xmas gifts. I googled around and could not find any. I can also use a small wattage guitar amp PCB and have the know how on making the modifications. Thanks for any assistance. I can use a PCB for any pentode (6au6 thru el84, etc). Basically just need flea power.
Hello,
Tubelab.com may be your ticket. You must have the output transformers ready to go?
Check out this thread.
http://www.diyaudio.com/forums/tubelab/172298-simple-p-p-board-parts-kits.html
DT
All just for fun!
DT
All just for fun!
Hello,
DT
All just for fun!
Thanks, I looked thru the 5 pages of discussions and only saw a link for a PCB for an SE board. I my have missed the link for the board. Need a PP board.
Hello,
Send George at PM. His User Name and website is Tubelab.com .
DT
All Just For Fun!
Shannon Parks also has a PP EL84 board based closely on the Dynaco Stereo 35 circuit. You'll find the board here: diytube.com :: View topic - the diytube ST35 board *SALE!!*
Although in all honesty, neither the Tubelab Simple PP nor the DIYtube ST35 is really a headphone amp. Either one should make at least a good 15 watts per channel, which is well above what I'd consider "flea" power.
This is actually perfect. Going with an st35 stuffed board. Thanks
