I'm looking for a powered sub for use in an active crossover biamped setup. What I'm hoping for is a sub with either no internal filter (I know, probably unlikely) or one that can be defeated/switched off.
I'm I dreaming? Can anyone make a suggestion?
Cheers.
Cheers.
I think you're dreaming, but most plate amps have crossover point controls, so you could just turn that up to the maximum to get the filter as far away from your active crossover point as possible.
Kensai
Kensai
