Powerbass XTA2250D
With the outputs installed the amp draws excessive current .
Here is a pic of the driverboard .
Is there something on the driverboard that usually goes bad ?
Anyone have a high resolution picture of this driverboard ?
Or know the values of
R45
R6
R22
R29
As you can see in the pics they are burnt .
Do you have a picture of the entire driver board ?
It appears someone has worked on this before and wanna confirm the values are correct . Also I found another burnt resistor R24 near the bottom right of the board
It appears work has been done on this before and wanna confirm the values are correct .
