Power Transformer
They did not do solder joints on this transformer. Everything is on screw terminals.
Does the CCAW magnet wire go all the way to the terminals? Or is there a copper pig tail which is brought out to the terminal? The former is reliable with the proper terminals - and more importantly, Re workable. If there is a joint of any sort buried in the over-wrap insulation you cannot get to it, and can’t re-solder CCAW anyway. A screw terminal, rated for aluminum wire, is preferred.
Aluminium wire in screw terminals calls for another issue, the creeping. Unless you're using specialized terminals for this purpose, you'll have to re-srew the terminals from time to time to avoid increasing contact resistances.
Here in Germany transformers were wound with aluminium wire during WW II, as copper that has to be inported became tight and expensive. They used EI cores with increased winding windows instead of lossless ones then. Later, even house wiring was done with aluminium in the GDR.
Best regards!
I know all that. Every technical solution has its own problem. Tightening screws is one thing, loosening solder joints is another, and so on. When you buy large transformers for industry, you have both aluminum and copper transformers on offer. How much money, that much music.
Here's something to consider for those concerned about what wire is in your transformer. The power lines to your home are copper clad steel. The pole transformers have aluminum wire. The wire from the pole to your residence is aluminum. The circuit breakers have contacts made from some sort of copper alloy. There are miles of non copper alloys between your amplifier and the power company.
Reactions: TonyTecson
Only the one who made it knows such details. The owner just has to hope it's done right. If the postage is not too high, and if the transformer does not buzz, it is a very good purchase. We have small companies here that make high quality trsnsformators, but not at that price, of course.
CCAW doesn't sound different per se than magnet copper wire, especially not in power transformers. An amplifier that allows you to listen to it's power transformer's »sound« is a poorly designed one. But remember that specific conductivity between aluminium and copper are different by a factor of about 1.5. So aluminium wire cross section has to be 1.5 times bigger than that of copper wire for the same resistance. Hence the transformer needs a bigger core for the same VU rating.
Best regards!
i do not get it when people look down upon aluminum conductors, even here in Manila folks are prejudiced against aluminum......the pice of copper magnet wires have gone up more than 300% since the covid 19 pandemic...
I know that there are steel cables for high frequencies (the central conductor of the coaxial cable), coated with copper and some with silver (I have one). Because of the skin effect it is possible of course. But for 50Hz - Aluminum and Copper only.
