Power transformer impedance
I am going to use a 6X5GT tube rectifier in my power supply.
From the data sheets it needs at least 150ohms of limiting resistance on each plate (for capacitor input).
By measuring the power transformer I get
- 18 ohms across primaries (100V) whilst shorting a secondary
- 275 ohms across secondary (320 to CT) whilst shorting primary
So I think I have Rt=Rs + (n^2)*Rp
=275 + (3.2 ^ 2) * 18
= 454 ohms on each plate.
(PSUDII gives the same result).
So I don't believe I need to add any additional resistors.
Does this calculation look correct?
Does my measurement of the secondary look correct?
(it didn't seem to change whether I shorted the primary or not).
Thanks!
Jeff
