I bought used one from ebay for my 6v6 SE Amp Project.
The seller said it would be perfect one.
When I got and measured secondary taps without rectifier, the tester showed 330V. You know it is too high for 6V6 SE Amp. I claimed to the seller, but he said "the voltage will be ok when you connect it to tubes."
Well, I cannot understand his reply. For instance its heater taps is measured as exactly 6.3V. According to his logic, the heater voltage will also go down, when I attached it to 6V6 SE circuit.
Thanks.
Thanks.
