What are the pros and cons of using sockets for power transistors. (TO-3 and TO-220)? I like the idea of not having to solder (and desolder for replacement or modification) the leads directly but am concerned about having good contact (and cooling with TO-3).
I have one amp that uses TO-220 for drivers and output transistors and my plan is to bolt directly to the heat sink (using heat sink compound) and then isolate the entire heatsink from the chassis. I would like to use sockets or some other push on connectors for the wiring though. Any advice on this (whether to do it and what to use for connections).
mike
mike
