I'm looking for a 3 position off-on-on double pole switch.
I'd like it to function in the following manner:
OFF - Everything OFF
1st ON position: Amp ON + Accessory #1 ON
2nd ON Position: Amp ON + Accessory #2 ON, switching Accessory #1 OFF
Switching between the 1st and 2nd ON positions, I DO NOT want the Amp to intermittenly switch off during the transistion.
Any thoughts or help would be greatly appreciated.
-Charlie
-Charlie
perhaps you can use a rotary switch, there are 2 pole 3 position make_before_break types that might do what you want
Thanks for the Reply, Yai.
I've come up with a suitable solution.....One main power toggle switch (DTDP) and a similar smaller toggle to switch between the accessories.
-Cheers
-Cheers
