Power Supply Voltage For 5881/6L6 Amp
Hi there,
The power transformer in my 10-year-old Arion Elektra tube amplifier has failed. No schematics came with the amp and there are no discernable markings on the transformer.
Tubes are 4x5881(6L6), 2x6SN7, 2x5814A(12AU7/ECC82). The brochure described it as an 18 Watt pure class A triode coupled pentode design.
Does anybody have any idea what the likely power supply voltage would be for such a design? (I'm guessing 350Vdc off a 250Vac secondary but that's just a raw guess.)
Arion also sold the Adonis kit amplifier, which had the same tubes and may well have had a similar circuit design. I have attached rough schematics for this kit amp that I got from an enthusiast via the 'audioasylum' web site in case it can give you useful clues to the design of my Elektra.
Many thanks guys, Simon in Edinburgh
no I think you will likely need more, is it a ss rectifier.
factor on 450 volt on the anodes
lose 10 volts in the choke if there is one and output tx,
so you are looking at perhaps 350-0-350 with a hefty current, 200 ma, and 6.3 volt heaters, lots of them 6Amps plus, try hammond or silk.
Schematics Request
Dear friends:
I am looking for the schematics of the North Ireland apmplifier ARION "ADONIS".
I bought this kit several years ago and now i am trying to bring him alive again but I need to coorect some components.
Unfortunatelly I missed my copy of the Electric circuit and will apprecioate any help from you getting this schematics to work with
Looking forward for any comment.
Truly yours,
Nelson //
Good evening All,
Looking for information about this amplifier Arion acoustics, not sure about model.
Any help appreciated.
Best regards.
Sasha.
