Power supply transformer output voltage 4 vs 8ohm ?
Hi everybody !
I want to build New amplifier and I try the SF60 PCB and the voltage transformer have big range Choice of 22 to 36-+ vac.
How determine the best Power supply voltage and why in lots of cases the transformer voltage is reduced when you setup amplifier Board for 4ohm speaker vs 8ohm ?
Thanks on avance 🙂
nicK
