Power Supply Questions
I'm currently leaning towards the LT3080 due to it's lower noise. I found this circuit (http://www.awdiy.com/uploads/pdf/LT3080-PSU-DIY-1.0.pdf) which is pretty much the standard configuration with a soft start. I'd also planned to use a pot to fine tune voltage, but just by a couple of volts. Per the data sheet, the noise in Rset is the biggest factor in controlling output noise, so I'll use high quality metal films and cermet pots, and keep the pot around 300 to 400 k (3-4V).
It even uses my LED trick to provide a small load and visual indicator.
One thing I don't fully understand (remember, I'm still a bit rusty) is why the diodes in the bridge are bypassed with caps. I figure it's to snub spikes during the switching while only passing frequencies too high to worry about in rectification.
Still have love for the LM3X7's, and those links are great reads.
I do have a TO-3 Package LM317K but i only managed to get one 🙁
But yeah , the hermetically sealed TO-3 and P packages are and is extremely tough , you'll need a tank to smash it . 😀
I find it useless now tough , is there a negative version of LM317 ?
Or something similar to LM7809 but much more powerful in terms of current .
Hi guys ...can you help a non technical guy
I have 2 power capacitors each 2200uf 100v in my power supply . The guy who built the amp has put discharge resistors across them . My question is will these affect either the sound of the amp or performance of the power supply . Thanks and sorry for intrusion Dave
