Hey all,
Looking for a 5V 1amp plus power supply. What do you guys recommend? Sadly my skills at building are rubbish so one that's built and boxed would be good!
I've seen this on ebay... wondered what you thought...
3x LT3045 Ultra Low Noise Single Stage Regulation Power Supply, 3-15V Out , 1.5A | eBay
Thanks, Tim
Thanks, Tim
You haven't said what it is for and what any noise and ripple requirements might be.
The one you have linked to looks to be just a 5 volt regulator and still needs an external mains power supply to feed it.
CPC do literally 100's of SMPS types, many under £10 such as this one:
https://cpc.farnell.com/ideal-power...su-5vdc-3a-c8-vi/dp/PW04182?st=power supplies
Most have data sheets so you can compare.
Ah sorry it's for a Topping D50 dac. Looking for one that is very low noise and also doesn't chuck a bunch of ac noise back into the mains that could affect my other equipment. I'm an audiophile so not after the cheapest option. Looking for someone with experience here rather than finding random power supplies on ebay.
Cheers, Tim
Cheers, Tim
So it sounds like you do want a linear supply then. I can't just think of any that are nice to look at and already boxed up and ready to go.
A linear supply is little more than a transformer, rectifier and cap/s and a linear regulator.
The one you linked to could easily be fed from an SMPS and there is no reason to worry over stuff going back in to the mains. You probably already have loads of those supplies in use at home anyway, router, phone etc etc.
Yep makes sense, I do like to think I'm not adding too many SMPS's too the system regardless! Are there any you guys have measured and think are decent? There are millions around so I can randomly buy one but was hoping for expertise.
Cheers Tim
Cheers Tim
I don't know of any tests as such but I'm pretty sure a suitable SMPS used to feed something like the supply you linked to would give a very clean result. The data sheets should quote the ripple and noise present at the output.
From what I see you would need something like 8 to 12 volts feeding it. If you go to high then power dissipation will increase. The LT3045 regulator is a low drop out type and only needs a very small overhead to work correctly.
It would be worth checking what range of voltage can be applied when you have it set to 5 volts and want to draw say 1 amp.
- Power Supplies
- Power supply question...
