hi, i had just built a gilmore amp, but i tried using only the lm317/337 regulators and not the opamps (bad idea), $8/chip and 4 chips was a bit much. the balance was a tad off, so here's a slightly cheaper idea that combines Mr. Elliott's shunt regulator (here, at bottom) and the lm317/337 preregulators from Mr. Gilmore's design.
schematic
do you think it will work? and are there any ideas for improvement?
the parts are on their way here.
thanks in advance
schematic
thanks in advance
Hi name773,
You will blow your transistors in this way. The zeners and the Vbe of the transistors (D5+Q1 and D6+Q2) will make 15.7V shunts, but the only current limiting is by the 317/337 preregulators, around 1A. You should use some resistor in front of the shunt regulator, like R1+R2 in the design of Rod Elliott. Just move your R5 and R6 to the left side of D5 and D6.
Or change the circuit around the 317 and 337 into floating current source and sink. Most datasheets of 317/337 show you how.
Steven
Steven
