Power supply noise problem.
Hi
I have build a reciewer containing a RaspberryPI 3B, a IQAudio PI_DAC+ and a Yuan-Jing (YJ) Blue/Black 2.0 Board( with modufication from this link🙁http://www.diyaudio.com/forums/diyaudio-com-wiki/252663-tpa3116d2-boards.htm).
For PS I use a laptop PS 19V5 output directly to amp. and a UBEC 5V/3A DC-DC converter. for the PI.
It's grounded to the chassis.
I this constellation I have a lot hiss and noise in the loudspeakers.
If I use a USb PS instead of the UBEC, it's gone ...no noise.
Can anyone tell me what is wrong with the UBEC?
I have measured the AC on the 19V5 and it's about 20mVAC and for the UBEC it's about 2mVAC.
Thanks in advance
Bjarne
Either need a separate 5V mains supply for the Pi or a ground loop isolator in the audio inputs to the amp from the Pi.
There are isolating DC/DC converters available for around £10 which do 1.5A output. This might be enough for a Pi3 or it may not!
