power supply for superpro 707 DAC
What would be an improved power supply for superpro 707 DAC
I have the superpro 707 Dac. I like it but what fun is it to leave well enough alone?
I'm curious to know if a better, custom power supply might improve the sound. If so, would it be a relatively simple supply thats doable for a diyer whos not an engineer or does it require something complex?
Would love to hear some suggestions.
If you read all the "audiophile" web sites, you will come across a zillion "improvements" that make a night and day difference - according to the person that made the mods. Will you see any measurements, or blind ABX logs that would actually prove the result? Of course not.
I should put the schematic up but I'll have to hunt for it.
Can you generalize from your experience with other DACs what characteristics of power supplies seemed to make the most difference?
My electronics experience is limited to following instructions but I'm guessing a regulated linear supply. I suspect something about adequate capacitance for 'filtration' might be important? Im really rather clueless although im trying to use this as a good project to learn more about power supplies.
Yes, a good, regulated supply is the place to start - but unlike a power amp, you don't need huge capacitors. Instead, HF characteristics are more important, so small filter/bypass caps are essential. You might even consider a series choke (inductor).
On the other hand, with a DAC, the real issue is preventing noise from the digital/processing parts from affecting the audio side and the clock. That is really something that has to be taken care of in the DAC, and the power supply can't do much there.
