power supply for Mosfet matching
minimum load
Just put a 5ohm 5W resistor across the 5V output and that will take care of the 1A minimum load. The other outputs usually don't have a minimum load. I used a computer power supply with just that resistor for a few years, and It worked great. Now I am building a diy power supply from my SOZ. (I couldn't take the heat so I built a pair of zen's)
The output ground, case and input ground are all tied together so don't try chaining unmodified supplies. (Yes I have stacked these things)
Darrell Harmon
