Power supply for balanced input stereo amplifier
I am currently working on a stereo balanced input amplifier project and wanted to share with you an idea I had about power supply.
It is based on following assumption:
- most of the power if used to produce low frequencies
- low frequency signals are mainly the same on two channels
So the idea is to cross the input and output of one of the amplifiers and use the same power supply for both, so that when an amplifier drags current on one supply rail the other drags current on the other rail.
The result is:
- smaller caps
- smaller tranformer
- smaller ripple
- smaller radiation
A properly designed balanced amplifier will have a constant current draw on the power supply.
Look up EUVL's F5x for an example.
This constant current draw is very rare among all the various topologies used for amplification.
This constant current draw does give significant performance improvements.
A balanced input for an amplifier does not approach the specification requirements for a constant current draw amplifier.
...So the idea is to cross the input and output of one of the amplifiers and use the same power supply for both, so that when an amplifier drags current on one supply rail the other drags current on the other rail.
The result is:
- smaller caps
- smaller ripple
- smaller radiation
Yes, that should give less supply ripple especially with low bass notes. I seem to remember this being done in some commercial amp, might have been NAD?:scratch:
Starting with balanced inputs certainly makes it easier to reverse one channel.
I misspoke about constant current draw, I meant equal current draw resulting in a zero difference in current flowing from zero volt node (gnd) to each PS cap bank. this is the VAS section, each +/-10V output is for two seperate output followers for BAL output.
So the idea is to cross the input and output of one of the amplifiers and use the same power supply for both, "so that when an amplifier drags current on one supply rail the other drags current on the other rail".
The result is:
- smaller caps
- smaller ripple
- smaller radiation
That was bridged amplifier.
-smaller transformer = not really. The power drawn is just same, even bigger because more drop voltages on amplifier (less efficiency). You may get fewer copper needed (smaller secondary cables for winding, because for same power, Vout is doubled, current is half, but power is same.
-smaller caps = yes, for half current like above.
-smaller ripple = no, because the capacitor is also smaller.
-smaller radiation = ??? what radiation.😕
Remember, with same current, same voltages, same power, the load resistance is 4:1 for series and paralelled.
Ups, my mis understood, sorry.
Still, transformer core should not be reduced, and secondary copper could smaller. The ripple is remain higher if you reduce the caps. And if it is stereo there must be a moment that they draw current not like you wishes.
