Greetings everyone,
If my power supply is located two or so feet from the amplifier, should I use shielded cable for the bias voltage? The filament supply will be located in a separate cable assembly from the "DC" supplies and all cabling will be done with teflon coated wire.
Thanks,
Ray
Thanks,
Ray
