I am making a mouser order for general experimentation purposes. I have put a great many of suggested transistors in my cart, but now I need to make sure I have enough resistors.
In my tube amp component stash, I have a healthy supply of 2 watt metal oxide resistors, a similar stash of 1/2 watt metal film, and a decent pile of 5 watt wire wound.
I lack resistors below about 10 ohms, and really anything below 100 in much variety of values. I know that the emitter resistors in the output section are quite small, and need to have some degree of power handling, right?.
What would be a good selection of values/power ratings to get me going? Think 100 watts or less of output if that matters.
Hi Dan
Emitter resistors discussed here: http://www.diyaudio.com/forums/solid-state/209141-emitter-resistor-output-stage-transistor.html
and Doug Self here: Distortion In Power Amplifiers
0.22R to as low as 0.1R at 5 watt are common values for this section of circuitry.
Cheers / Chris
Cheers / Chris
I'm looking for metal plate/element emitter resistors, but i can't find seller everywhere.
Why they don't longer produced?
Noble is very good, but no seller on the web.
Yageo have only a few value low too. Not good if you are many transistors parallel
Futaba can't find everywhere.
I've worked on an amp with MJ15024-25 output transistors that used two each 1 ohm 5 w in parallel to make .5 ohm @ 10 w on each output transistor. These were flameproof wirewound resistors, I believe. Other schematics I've looked at used .39 ohm 5 watt or .33 ohm 5 watt. The higher the emitter resistance, the less sensitive the amp is to matching the output transistors, IMHO. At least the amp I worked on that had the .5 ohm 10 w, the factory had stated any transistor bought from them with the right PN would work without matching.I know that the emitter resistors in the output section are quite small, and need to have some degree of power handling, right?.
I monkey with battery chargers and car ignition circuits also, and have found it convenient to keep around 1 ohm 25 watt and 2 ohm 20 watt resistors, also. A resistor in series with the diodes in a battery charger keeps from burning up a $100 power transformer if lightning shorts out the diode. And you can't buy ballast resistors for cars anymore from the auto supply that last more than a year outside: the crimped connections corrode over. I had to make a 1.6 ohm resistor with solder joints. The 12v battery chargers for sale now are full of electronic control gimmicks that you can't leave plugged up in a lightning storm.
@ Walkalone
Here's one company who makes them WELWYN Just one example of many values etc available WH10 0R2 JI - WELWYN - RESISTOR, 15W 5% 0R2 | Farnell United Kingdom
WELWYN in CHINA Sales :: Welwyn TT & lots of other countries 🙂
