Power rating of resistors
Seeing that you posted in Analog Line-Level, indicating a filter position ahead of the power amp, chances are we're looking at 1/4 W metal film.
Mind sharing the filter topology you had in mind? If you do need something passive between power amp and speaker, be aware that crossover filter designs only tend to be using as much resistance as needed to match sensitivity between the drivers, otherwise they tend to be relying on LC filtering as much as possible - efficiency with RC filtering would be terrible. Speaker design software is advisable for good results, speaker drivers have a habit of not being terribly resistive in nature.
The same as the impedance of the midrange speaker for which you are designing the band-pass filter.
(Assuming you are using one mid per channel - if more than one per channel then supply more detail.)
Yes, you would use the total impedance of the combination.
However, a total of 2 ohm is rather low and you would have to be sure that your amplifier can handle a 2 ohm load without fear of damage to the amp.
The alternative is to have two 4 ohm mids in series (8 ohm total) or two 8 ohm mids in parallel (4 ohm total).
