Power rating for short circuit protection in linear voltage regulator
Question about the short circuit protection transistor with current booster in this type of circuit (attached)
As Iout*Rsc develops enough vbe Q2 to start shunting current away from the base of Q1, does that mean that Q2 only has to handle (at most) the base current of Q1? Or am I missing something here?
Short circuit protection doesnt need an additional transistor.
Max current of the regulator is 1A , hence the max voltage through R3
will be 3V , the max voltage across RSC will be 3 - 0.7V = 2.3V so the max current
through the transistor is 2.3/RSC.
All you have to do is to size RSC according to
