I bought a used Pioneer GM-D8604 4 channel class D amplifier a few weeks ago.
I suspect that it has been repaired before. It looks like FETs and rectifier ICs have been replaced.
The problem I have been facing is that the "Power Rail Capacitors" make high pitched noise only when amp is cold.When amp warms up a bit noise becomes less. I replaced the capacitors 50v/2200uF and the noise problem had gone. But after a week the noise came back.
Can somebody please guide me what is causing these capacitors to go bad.
Sharing the amps schematic for this amp will be highly appreciable.
ABDUSSALAM
ABDUSSALAM
- Class D
- Power Rail Capacitors making whistles.
